57 shifter handle?? - NCRS Discussion Boards
57 shifter handle??
  • Darryl D.
    • February 7, 2017
    • 386
    57 shifter handle??
    My 57 did not come with a 4 speed from the factory--too early of a car. The car was later fitted with a Muncie trans and a shift handle that APPEARS to be an original 57. It bolts to the Muncie shifter. Did the original 57 handles bolt to the original for 57 Borg-Warner shifter? If not, maybe the handle I have is the aftermarket one as shown in this link.
    http://keenparts.com/pages/detail.ph...partnum=340002
  • Don H.
    • December 1, 1981
    • 1499
    Re: 57 shifter handle??
    I would say you should EASILY be able to tell if it is a stock shifter or a Hurst. The throw and "tightness" will tell you. Also if the handle bolts on like in the picture, it is not stock. The stock shifter is one unit, not a handle bolted to it. Don H.
    • Darryl D.
      • February 7, 2017
      • 386
      OK, you answered my question in a round about way stating "The stock shifter is one unit, not a handle bolted to it." However, for your future information the handle in the picture in the link is NOT a Hurst handle but rather an aftermarket item made by another company so you can have the original "looking" shifter used with a Hurst shifter. Apparently it must also bolt to the Muncie shifter I have since you say the original 57 shifter handle used with the Borg-Warner linkage is not a bolt on item.
      My Muncie shifter is worn out so I am going to replace it with a new Hurst unit and I needed to know if I needed another handle but it looks like I am good to go there.
