Speedometer Cable - NCRS Discussion Boards
Speedometer Cable
  • Frederick W.
    • February 1, 2006
    • 33
    Speedometer Cable
    What is the length of the speedometer cable on a 1961 with a 4 speed transmission ? Also is the back side of a 1957 grill surround and teeth marked with the part number, as I what to sell it and the extra teeth , so I know how to list it . Thank You Fred
  • Don H.
    • December 1, 1981
    • 1499
    Re: Speedometer Cable
    Although I haven't check the Corvette parts suppliers, most replacement cables I've seen are cut to length and a squared end attached. So you would cut the new one to match the old or if you don't have an old one I suppose you would use the housing to determine the length. A word of caution, do NOT use a plastic end (the squared piece you attach). I just had to pull my dash to get the broken plastic end out of the tach. Also the kits I have seen use an anvil type piece to squash the metal end to the cable which can distort it. I would recommend soldering the end on. Good luck, Don H.
    • Darryl D.
      • February 7, 2017
      • 386
      Corvette Central shows it to be 72" If it were me I would replace the cable and housing as the cable ends are better, it is a new, pre-lubed with no burrs on the inside and they are only $30.
      Don't know about the grille teeth but it may also be listed on CC as Jerry the owner started that business 40 years ago making grille teeth.
      • Chris S.
        • January 1, 2000
        • 1068
        the 53 to 57 grill oval is marked on the back with a GM part number - the repro number looks different than a real GM part
        Also the teeth have the part number and a single number
        The single number is cast way down on the inside towards the point of the tooth. The Center and largest tooth is cast with a "C"
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
