1971 ls6 double disk clutch - NCRS Discussion Boards
  • Thomas J.
    • March 10, 2017
    • 22
    car has m22 with double disk in it, anyone know if this was option or stock for ls6 car or did other cars come with this clutch set up ?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 1971 ls6 double disk clutch
    Stock, only with LS6 and M22 combination.
    • Thomas J.
      • March 10, 2017
      • 22
      thanks for reply
      • Mark E.
        • April 1, 1993
        • 4606
        Others know more details, but I believe this clutch was available (or part of the engine option package) with other solid lifter big blocks. Years ago, I had a '70 Chevelle SS L78/375hp with this clutch.
        I believe it's discontinued long ago by GM.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Mike E.
          • February 28, 1975
          • 5141
          Fine spline or coarse spline? 71 was fine.
            • 15625
            Stock for your LS6, as Mike said. It was an option with some Corvette engines in 1969 (maybe 1968 also, but I am unsure of that), but not a Corvette option in 1970-1972.
              • 43263
              Mark-------
              I have no information that any Chevelle ever was originally equipped with a dual disc clutch. I once was the original owner of a 1968 Chevelle SS 396 with L-78 and M-22. It did not have a dual disc clutch and I do not think that any 1969 or 1970 did, either.
                • 43263
                Terry------
                The dual disc clutch was used for only 2 Corvette applications ever. The first was 1969 Corvettes with L-71 engine and MA-6 dual disc clutch option. The second was all 1971 Corvettes with LS-6 and 4 speed transmission.
                  • 43263
                  Mike-----
                  1969 with MA-6 used 10 spline discs. 1971 with LS-6 used 26 spline discs. Otherwise, the clutches were the same.
                  Also, I believe that all 1971 with LS-6 and 4 speed transmission, both M-21 and M-22, were equipped with the dual disc clutch.
                    • 43263
                    Thomas-----
                    If you ever need any components of this clutch system you will probably need to convert to a standard single disc clutch. All of the GM parts for this clutch system are long-since GM discontinued and I know of no reproductions or aftermarket replacements for any of the components. Given that the market for these parts is infinitesimal, I highly doubt there will ever be available such parts.
                    Once-in-awhile one or more of the components comes up for sale on eBay at withering prices.
                    • Mark E.
                      • April 1, 1993
                      • 4606
                      Mark-------
                      I acquired the Chevelle in 1977 with about 75k miles, and sold it a few years later after a garbage truck turned left into the car while I was passing it. I cried that day, even though I wasn't injured. To add insult, the cop wrote me a ticket for unsafe passing. Apparently in California back then, if ANYTHING bad happened while passing, it's your fault. No matter the truck driver didn't signal or even look before turning.
                      I digress. When purchased, the power brake pedal had a custom fitted block mounted on top so its height closely matched the clutch pedal. Oh, the prior owner was about 5' 5" tall and had issues walking. I assumed the clutch was original, but maybe it was installed to reduce effort or travel?
                      Still, I'm surprised you don't think any non-Corvettes came with this clutch.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Dick W.
                        • 10483
                        Possibility that these folks can rebuild the dual disk clutch http://carolinaclutchandbrake.com/ I don't know of anything that has stumped them yet.
                        Dick Whittington
                          • 43263
                          Mark------
                          I have no information that any other Chevrolet model was ever originally equipped with a dual disc clutch. This includes 1970 with LS-6. The car of which you speak could have been retrofitted with one or it could have been retrofitted with some sort of aftermarket dual disc or other clutch.
                          • Thomas J.
                            • March 10, 2017
                            • 22
                            thanks for feed back clutch pressure plate all other parts look great car has 46000 miles on it
                            • Mike E.
                              • February 28, 1975
                              • 5141
                              The flywheel for a MA9-equipped car is unique, also.
