'65 Corvette - limited slip differential question - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1808
    Re: '65 Corvette - limited slip differential question
    Interesting, maybe they had enough calls to convince them I wasn't crazy when I said it locked on tight. I have stopped using in on diff plugs and had mixed reports back when I did. Most times the owner was able to remove the drain plug or fill plug without issue. Most of the time it was used on the drain plug I tapped in. A couple had a hard time until they put a little heat on it. I have taken apart boxes I tested it on and had to use a pipe on the wrench to break it loose.
    If you only uses a little you should be ok. Do you recall what thread it was I mentioned it on, I want to go back and edit it so others will know if they refer to it.
    • Oliver S.
      • December 1, 1999
      • 352
      Gary,
      here it is:
      https://www.forums.ncrs.org/showthre...489#post397489
      Oliver
      • Gary R.
        • April 1, 1989
        • 1808
        #18
        Thank you, I just addressed it.
