Re: Rag Joint Hockey Puck
Harry,
Use a continuity tester to ensure conductivity from the steering column flange side to the steering box side of the coupling. If wire mesh is in the coupling both bolts should provide the continuity path, but I believe only one bolt if a grounding strap was used.
Harry,
