Rag Joint Hockey Puck - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    I have gone through one reproduction rag joint, and another which I rebuilt myself using the "correct" rebuild kit with shouldered bolts and rivets.
    It has been suggested that the current rubber/fabric hockey pucks are not as strong as originals.
    Does anyone know of a source for good, strong rubber hockey pucks and/or a source where someone can rebuild mine using high quality rubber or used original hockey puck.
    It would be OK to use the service replacement/later style which has steel webbing for continuity, since the dimensions are the same, I believe.
  • Gary R.
    • April 1, 1989
    • 1804
    Re: Rag Joint Hockey Puck
    Joe,
    I think the rags that LICS has are about the best on the market today. The quality of the current kits and rags is not even close to what Saginaw made for GM. The only one who built a quality rag was Tom Reina and he stopped about a year before his death because he couldn't get the material anymore. That was 6 years ago he told me that. The best option is LICS or look on ebay but be prepared to pay over $200 for a NOS one. I had some but I am down to just one 67-E69 & L69-82 NOS rags which are not for sale.
    • Joe C.
      • August 31, 1999
      • 4598
      Joe,
      I'm considering replacing it with a straight U-joint from Borgeson. Maybe making a 1/4" steel replica of the hockey puck, painting it black and bolting it solid to the original flanges with grade 8 bolts. LICS is a consideration.
      I don't believe that there is much, if any movement or alignment issue between the steering box and the column. I feel that if I get perfect alignment between the two with the car at rest, then when subjected to severe cornering loads, there should be no variation.................unless the body mounts are in bad condition.
      • Patrick B.
        • August 31, 1985
        • 2011
        I wonder if it would be possible to stiffen the rubber disc by sandwiching it between two large body washers bolted through its center. This would preserve its vibration isolation function but reduce its flexibility.
        • Timothy B.
          • April 30, 1983
          • 5201
          Joe,
          I read your P/M but the only old rag joint I have here is the one off my 63 car but it's wore out also. I will keep a eye open for a NOS part for your car, the one in the picture resides on my 63 coupe. They pop up now and again on ebay, maybe try a wanted ad on the C/F.
          • James B.
            • March 1, 1985
            • 217
            Just saw this listing on eBay.
            112333761876
            James
            • Harry S.
              • July 31, 2002
              • 5344
              112333761876
              James
              Saw that also but I have no idea what the original PN was. It's not in the 63 AIM.
                • 43273
                http://www.ebay.com/sch/i.html?_odkw...76&_sacat=6000
                Harry------
                GM #5691327 is the original part number for 1963-66.
                • Harry S.
                  • July 31, 2002
                  • 5344
                  Joe, Thank You....
                  I bit the bullet and bought the NOS one on Ebay. I've been fighting a vibration for years and this is one of the last two fixes I'll try before I give up.
                  • Harry S.
                    • July 31, 2002
                    • 5344
                    Well the part arrived today, looks fine. http://www.ebay.com/itm/112333761876...%3AMEBIDX%3AIT
                    The part does not come with a ground strap. Other than cutting out one perfectly good rivet to attach the strap does anyone have other suggestions?
                      • 43273
                      Harry------
                      I don't think the ground strap is necessary on this coupling and I certainly would not remove a rivet and install one for the sake of originality.
                      • Harry S.
                        • July 31, 2002
                        • 5344
                        Joe, I think I need the strap for the horn ground?
                          • 43273
                          Harry-----
                          If I recall correctly, the version of the coupling you bought uses a different grounding path and does not require the strap. Jim Shea's past posts might shed more light on this.
                          • Timothy B.
                            • April 30, 1983
                            • 5201
                            Harry,
                            The NOS rag joints have the last segment of rubber fiber impregnated with a wire mesh which when installed provides the ground path for the horn.
                            According to Jim Shea, anytime there was an design change at Saginaw, the change (mesh) was implemented on all service parts. I believe the mesh started late sixties early seventies.
                            The purpose of the copper strap or mesh was to provide a positive ground path for the horn relay circuit. There are other ground paths also in the column but the mesh/strap was a positive ground path in the event the others developed resistance.
                            • Harry S.
                              • July 31, 2002
                              • 5344
                              Originally posted by Timothy Barbieri (6542)
                              Harry,
                              Tim, I just took a magnet that can pull fillings at 10 feet, I do detect the mesh. With a magnifying glass I can see it.
                              Thank you I'm all set.
