1971 ls6,carb - NCRS Discussion Boards
1971 ls6,carb
  • Thomas J.
    • March 10, 2017
    • 22
    1971 ls6,carb
    is having the right carb a must car? has 22 four speed but carb on it now is for auto and carb date is for 72
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 1971 ls6,carb
    A must NO. but a deduction YES.
    • Thomas J.
      • March 10, 2017
      • 22
      Re: 1971 ls6,carb
      I am trying to restore the car the air pump is missing also where can a guy find carb and air pump
      • Anthony F.
        • February 7, 2014
        • 79
        Re: 1971 ls6,carb
        I did a quick search on eBay, found this:
        Looks like it needs rebuilding, but this is such a rare piece it might be worth looking into.
        There is a carb shop in Middlesex, NJ ( Custom Rebuilt Carburetors, 732-356-4333 ), that might be helpful. They have a website.
        • Russ S.
          • April 30, 1982
          • 2162
          Re: 1971 ls6,carb
          Search Ebay for it and save your search so that Ebay will email you every time something is listed that matches your search description. Also for the air pump, check with Bill Hodel. He advertises in the Driveline. EXPENSIVE but restores them beautifully.!
            • 43219
            Re: 1971 ls6,carb
            Thomas------
            The carb will be VERY difficult (and expensive). The AIR pump is easy. The AIR diverter valve will be VERY difficult (and expensive).
            By the way, until about 10 years ago Holley used to reproduce this carb. Below are photos of a reproduction [not for sale].
            • Mike E.
              • February 28, 1975
              • 5138
              Re: 1971 ls6,carb
              Sent you an email through NCRS. Let me know if it didn't come through.
              FWIW, the eBay carb is a replacement service date. Closer to what you want, but still not there.
                • 43219
                Re: 1971 ls6,carb
                Mike------
                Finding a correctly dated example of this carb is going to be an exercise in futility. There were only two applications for this carb-----1971 Chevelle with LS-6 and 1971 Corvette with LS-6, both with manual transmission. No 1971 Chevelle LS-6 were ever made. That leaves less than 200 Corvette LS-6 with manual transmission. There were probably a small number of SERVICE examples of this carb manufactured during the 1971 model year which would also have correct dates. However, reducing the field even more, there were probably only about half of the carbs manufactured that would be date correct for any particular 1971 Corvette LS-6.
                • Dick W.
                  • 10483
                  Re: 1971 ls6,carb
                  If I remember correctly there were only three? batches of those carbs built
                  Dick Whittington
                    • 43219
                    Re: 1971 ls6,carb
                    Dick------
                    That could very well be. For an extremely low volume part like this, batch build would be expected.
                    • Mike E.
                      • February 28, 1975
                      • 5138
                      Re: 1971 ls6,carb
                      And weren't two of those three early in production?
                      • Thomas J.
                        • March 10, 2017
                        • 22
                        Re: 1971 ls6,carb
                        thanks russ I will look him up
                        • Thomas J.
                          • March 10, 2017
                          • 22
                          Re: 1971 ls6,carb
                          so far what I have been told is holley carb list #4803 3986195 was for 4speeds and list 4802 3986196 were for automatic and to be code corrert date should start with 153 or one something ????
                          • Thomas J.
                            • March 10, 2017
                            • 22
                            Re: 1971 ls6,carb
                            got your email looks like wrong date thank you for your reply
                            • Michael J.
                              • January 27, 2009
                              • 7122
                              Re: 1971 ls6,carb
                              This is a correct one for an automatic, early build.
