oil pressure gauge dancing - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    what makes the gauge flutter at idle and smooth out at cruising speeds?
    • 6960
    Re: oil pressure gauge danceing
    Frank, you just may want to test the oil pressure with a gauge first,this will lead you in the path of which way to go, gauge or pump. I am thinking that 73's are still a mechanical gauge still not electrical??
    • Edward B.
      • January 1, 1988
      • 537
      From your description it is impossible to tell weather it is a gauge problem or an engine problem. Install a temporary mechanical gauge and report back.
      • Jimmy P.
        • June 24, 2014
        • 1696
        Ed,
        Yes, you are correct, the 73 oil pressure gauge is still mechanical.
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
        • Frank K.
          • January 1, 2000
          • 319
          It is a 1977 car!
            • 6960
            Frank, I Believe by 77 the oil gauge is electrical Most of the time with these style Gauges the oil sending unit goes, But it really best to still Do a mechanical gauge test. If you don't have one, The oil sender is a 25-30 dollar part might be worth a try.
