64 327/365HP Oil Pan - NCRS Discussion Boards
  • Rick G.
    Infrequent User
    • October 24, 2007
    • 13
    Anyone know the correct oil pan? I have someone telling me I should have a 6 quart pan with a windage tray?
  • Don H.
    Moderator
    • June 16, 2009
    • 2274
    Re: 64 327/365HP Oil Pan
    Someone is correct except it is actually a 5 qt. pan making total capacity with oil filter canister 6 qts. Has longer lower part that takes away room for steering stabilizer or power steering piston. There is a trapdoor in the lower part and windage tray hanging from main bearing cap studs to control oil slosh.
    • Joe R.
      • July 31, 1976
      • 4551
      Your friend is correct in that the SHP 64 365 or 375 had a special pan with an extra quart including the oil filter. The last part number listed was 359942. You can find this puppy on E-bay for $1800.00 in the GM box with the flat windage tray included.
      And you can't add PS to this pan if you wish.
      JR
        • 43258
        Don------
        Just to be clear, the pan in the photo is not the "6 quart" pan; it's the "5 quart" pan.
          • 43258
          JR
          JR------
          Yes, the GM #359942 was the last available "6 quart" pan. It differed from the original GM #3820001 only with respect to the front oil pan gasket seal radius. Neither pan is currently reproduced. However, there are some NOS examples of the 359942 on eBay for less than $1,800. The $1,800 dollar one will probably be for sale for a LONG time, at least until the lesser cost ones are sold.
          Not that many applications require this style pan and that's probably why it's not reproduced. Tooling for an oil pan like this is very expensive and if the market is small, it just doesn't"pencil out".
          The only applications requiring this pan are 1963-65 with mechanical lifters, possibly a few early 1965 L-79, some early 1970 with LT-1, and all 1970-72 ZR-1. No other Corvette or other Chevrolet applications ever originally used this oil pan.
          • Dan A.
            • May 31, 1974
            • 1073
            Don------
            Hmmmmm.........
            • Keith B.
              • September 15, 2014
              • 1591
              does this look like the correct one
              • Leonard M.
                • September 7, 2009
                • 236
                Here's some pictures of one I sold. You should be able to find a real nice one for less than 300. Don't buy one with heavy rust you won't be happy with the pitting.
                SOLD I have a "6 Qt", long sump, trap door oil pan intended for the "Special high performance" small block 63-65 solid lifter, fuel injected and no P/S LT1. Nice paint, only a few tiny nicks, ready to bolt up and includes bolts. This is a very nice pan, beat up rusty ones have sold for more. No repairs, No welds, No bondo, minor dents as seen, Good drain plug and threads.
                $275. plus 15. shipping
                • Joe R.
                  • July 31, 1976
                  • 4551
                  Yep, that's it!
                  Wonder how many dents in that one? Great price for a good one!
                  JR
                  • Keith B.
                    • 1591
                    so did one of you buy that one on Ebay that I posted? sometime soon I will need to find one for dads new project
                    • Harry S.
                      • July 31, 2002
                      • 5332
                      Keith, there is one on the Corvette Forum. It looks to be in great shape. Go to C1/C2 parts. It's $450.00.
                      • Keith B.
                        • 1591
                        Yes l saw that. I will be looking at swap meets and local before we start looking online
                        • Harry S.
                          • July 31, 2002
                          • 5332
                          One of the tell tale signs of an original 3820001 is a rectangular nut plate is spot welded on the inside of the pan to accept the drain plug. The later oil pan, 359942, has a hex nut spot welded inside the pan.
                            • 43258
                            http://www.ebay.com/itm/OLD-VINTAGE-...FYu25p&vxp=mtr
                            Keith------
                            This is the "6 quart" pan.
