Lower Alternator Bolt Headmarks 70 sb no AC - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    My 70 had headers when purchased so no point of reference.
    What is the finish and headmark of the pivot bolt?
    What is the finish and headmark of the bolt that attaches the lower bracket to the exhaust manifold.
    Were both of these bolts painted with the engine? I am thinking so as the bracket is orange. If so should they show some orange or did the bolts get changed out when the alternator was mounted?
    Bill
    • 6950
    Re: Lower Alternator Bolt Headmarks 70 sb no AC
    Bill, I would say the lower bracket was orange, the adjusting upper bracket was semi gloss black, the adjusting upper bolt WB grade 5 zinc, the lower bolt I am thinking a C for the lower. head marks could be a number of different ones as always with most corvettes an sometimes the finishes depending on year.
    • Mike E.
      • February 28, 1975
      • 5141
      Bill,
      I will try to look at my L46 later today. Still going somewhat slow 5 weeks after heart surgery, but always looking for excuses to go to the shop. Good exercise, right?
      • Mike E.
        • February 28, 1975
        • 5141
        Bill,
        Bolt to manifold (lower) is R S C, while pivot bolt is T R. Both are grade 5 (3radial lines) and neither has any indication of orange paint. Have fun!
        Mike
        • Bill L.
          • February 1, 2004
          • 1403
          Originally posted by Mike Ernst (211)
          Bill,
          Mike
          Thank you Mike!
          God Speed with your recovery.
          Kind Regards,
          Bill
          • Bill L.
            • February 1, 2004
            • 1403
            Thank you Edward!
            Kind Regards,
            Bill
              • 6950
              Bill, one other small note on the alternator adjusting bolt, its threaded end should extrude beyond the alternator ear, generally they are flush. so the thick flat washer and lock washer and bolt makes the correct bolt flush.
              • Bill L.
                • February 1, 2004
                • 1403
                Thank you Edward. That is what I have for the Adjuster bolt with SBC head mark.
                Kind Regards,
                Bill
                • Mike E.
                  • February 28, 1975
                  • 5141
                  As per the first paragraph of the 70-72 JG, p. 127
                  • Bill L.
                    • February 1, 2004
                    • 1403
                    I need to really get a copy of the new JG.
                    Kind Regards,
                    Bill
                    • Mike E.
                      • February 28, 1975
                      • 5141
                      Actually, the JG doesn't talk about your question, Bill. It spells out Edward's answer to the question you didn't ask. Sorry that I confused things.
                      Mike
