1973 1974 differential codes - NCRS Discussion Boards
  • Howard K.
    Infrequent User
    • September 30, 1979
    • 17
    Does any one have any information on 1973 and 1974 differential codes? The judging manual lists two codes for the 3.36:1 rear differential. These two codes are AX and LR. Were these two rear axles interchangeable? Or was their use based on the date of installation? Or was their use based on the engine or transmission (driveline) configuration? Thanks for any comments to help clear up this issue.
    • 43279
    Re: 1973 1974 differential codes
    Howard------
    I believe the difference was the type of installed yoke axles. One of the codes would have denoted a unit with u-bolt type axles and the other would have denoted a unit with cap-and-bolt type axles. I don't know, for sure, which was which but I expect the "AX" code denoted the cap-and-bolt type axles and the "LR" denoted the u-bolt type axles.
    I would expect that the base engine with standard axle ratio received the "LR" while all other uses of the 3.36:1 ratio received the "AX".
    • David R.
      • April 30, 1991
      • 42
      I can confirm from my original-purchase '74 build sheet for L48 base engine, M20, its 3.36 axle code was LR.
      78 white L82 M21
        • 43279
        David------
        Does your differential have u-bolt type stub axles?
        • David R.
          • April 30, 1991
          • 42
          Sorry Joe, car was sold at 5 years old, pictures-if any, are boxed away somewhere?
          78 white L82 M21
