Question for Joe Lucia: PF-35L - NCRS Discussion Boards
  • Larry E.
    • 1703
    Will be changing oil in some of my old vehicles this Summer. Most of them came with PF-25. I assume
    the PF-35L is still around with better filtering ability. What is the current GM P/N for this filter?? Thanks
    in advance. Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Chris S.
    • January 1, 2000
    • 1069
    Re: Question for Joe Lucia: PF-35L
    I think the filter changed to the PF1218
    • Larry E.
      • 1703
      Chris: The number you gave me I believe is for the regular PF25. Anyway happen to stumble on my answer;
      I think the correct number is #25013454. Please correct me if I am wrong. Larry
      Larry
      • Chris S.
        • January 1, 2000
        • 1069
        Pretty sure I am correct
        I used to use the 35L and they changed to the 1218 - the 1218 now has an antidrain back valve.
        the 1218 is a tall filter like the 35L
          • 43296
          Larry------
          The PF-35L is still available and the part number is GM #25013454. This is a synthetic media oil filter and is what I recommend.
          The PF-1218 is the replacement for the old PF-35 (NON "L" suffix). It's a conventional media filter.
          There used to be a GM filter known as the UPF-1218. This was a synthetic media filter. However, it's discontinued and replaced by the PF-35L. I like the UPF-1218 because it had the same benefit as the PF-35L PLUS it had a teflon coated gasket which makes removal much easier. I bought a "lifetime supply" before they were discontinued.
          • Larry E.
            • 1703
            Joe--
            Thanks again; you are the best!
            Larry
            • James B.
              • March 1, 1985
              • 217
              Joe,
              Any fitment/clearance issues of the PF35L for 1972 Corvette with 454?
              I ask, because some of the online fitment tables does not specify this filter fits (even as an option) for my application.
              Thanks.
              Jim
              • Jim T.
                • March 1, 1993
                • 5351
                I use the PF35L on my 1968, 1970, and 1985 Corvettes.
                • Mark E.
                  • April 1, 1993
                  • 4614
                  Originally posted by James Burrell (8408)
                  Joe,
                  Thanks.
                  Jim
                  No problems with a stock exhaust. Headers sometimes get in the way of longer filters.
                  The even longer 2 quart PF932F will fit and drops down to almost the bottom of the oil pan. But it doesn't use synthetic media like the PF35L.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                    • 43296
                    Joe,
                    Thanks.
                    Jim
                    Jim-------
                    No fitment problem, at all. It will work perfectly.
                    • Gary R.
                      • April 1, 1989
                      • 1808
                      Joe how does this filter compare to the Wix gold filters? I am down to about 1/2 case so I will be looking to order more.
                      Gary
                        • 43296
                        Gary
                        Gary------
                        If you're talking about the Wix XP filter, it's comparable to the PF-35L.
                        • Larry E.
                          • 1703
                          Another Question for Joe: Is there any (PF141) canister type filter out there that has the
                          characteristics of the PF35L?? Thanks in advance--Larry
                          Larry
                          • Gary R.
                            • April 1, 1989
                            • 1808
                            what is the benefit from the different media's used?
                              • 43296
                              Gary------
                              Much greater single pass filtering ability and smaller particle size retention.
