1970 Courtesy and Door Ajar Switches - NCRS Discussion Boards
    Infrequent User
    • January 25, 2017
    • 14
    Does anyone have a source for (SX) 1970 Courtesy and Door Ajar Switches?
    The ones from Lectric Limited are longer than the originals.
  • Leif A.
    • August 31, 1997
    • 3653
    Re: 1970 Courtesy and Door Ajar Switches
    Would these be the ones...
    https://www.paragoncorvette.com/c-22...aspx?pagenum=2
    Front Courtesy Lamp Switch
    Front courtesy lamp switch. 1975-78 L.H. 1979-82 R.H.
    Years: 1975 - 1982
    Condition: New
    Packaging: Each
    Type: Stock
    (read more...)
    12445
    Price: $14.00
    I know it says '75 - '82 but thought they may be the same.
    Leif
    • Rich P.
      • January 12, 2009
      • 1361
      I have several sets of courtesy switches and 1 set of ajar switches.
        • 43277
        Years: 1975 - 1982
        Condition: New
        Packaging: Each
        Type: Stock
        (read more...)
        12445
        Price: $14.00
        Leif-------
        These are not the same as the 69-74. The 69-74 used GM #3928753 for the courtesy lamp switch and GM #3929804 for the door ajar switch. Both are GM-discontinued but available in reproduction. There are also quite a few NOS examples of the 3929804 still around but I don't know if the later SERVICE examples still had the "SX" embossment on the head.
        • Bill L.
          • February 1, 2004
          • 1403
          Could it be they are longer because when installed at the factory they were self adjusting and actually collapsed inside the shell to set the switches.
          Just a thought.
          Kind Regards,
          Bill
          • Sal C.
            • December 1, 1984
            • 430
            The last ones available that Joe mentioned did not have the correct head markings. The 1975 and newer are totally different, including the type of electrical connection.
            • Mark M.
              • October 21, 2008
              • 343
              John, check an ebay seller called ( glenn454 ). I've bought c3 used parts from him before and he's reasonable on pricing. He has a number of those switches on now in different conditions. It's a gamble buying used parts like switches but these are originals. Good luck
                Infrequent User
                • January 25, 2017
                • 14
                Thanks all
                • Mike E.
                  • February 28, 1975
                  • 5141
                  John,
                  I have purchased several NOS ones with the correct type of receivers for the electrical connectors over the years. I have then removed the SX pins from my old ones and swapped them with the new ones. That has worked for me.
                  • Rich P.
                    • January 12, 2009
                    • 1361
                    • Kenneth T.
                      • March 23, 2008
                      • 631
                      John, check out Ecklers. http://www.ecklerscorvette.com/corve...1968-1974.html
                      I have looked at them but have not purchased, so I cannot attest to the quality, but it is worth a try.
                      Ken
