1963 ignition switch - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Does the key come out in the off position and can the car be started without the key from the off position? Thanks in advance.
  • Harry S.
    • July 31, 2002
    • 5349
    Re: 1963 ignition switch
    The key comes out in all positions except ACC as I recall. What number is on the switch? It should be 635.
    I believe there is a description in the Owners Manual.
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 941
      Harry, The owners manual states what positions the key can be removed. I don't have one here in the office. I don't think it comes out in one of the other positions.
      • Harry S.
        • July 31, 2002
        • 5349
        Joe, you be correct. Went to the cold garage and got the owners manual. Key can not come out in the OFF and ACC position.
        • Joe R.
          • July 31, 1976
          • 4552
          According to the 635 and key set I have in my hands presently the key can be removed in the lock and on positions.
          JR
          • Bob W.
            • December 1, 1977
            • 803
            If a 635 is for a 63 what is a650 for ?
            • Joe R.
              • July 31, 1976
              • 4552
              Looked it up and low and behold a 650 is for a 63 or 64. The 635 is listed in the AIM as the ignition switch for a 63. Must have been changed as I have both and they are identical.
              JR
              • Bob W.
                • December 1, 1977
                • 803
                JR Thank you for the reply.
                • Gerald C.
                  • June 30, 1987
                  • 1321
                  Where would I find the number 650 on my 1963 ignition switch?
                  • Gerald C.
                    • June 30, 1987
                    • 1321
                    Please disregard this reply as I found the numbers.
                    • Gerald C.
                      • June 30, 1987
                      • 1321
                      I am now looking for an ignition lock with just one hole in its face. Any sources?
                      Jerry
                      • Harry S.
                        • July 31, 2002
                        • 5349
                        Jerry, you don't need the entire lock. The piece with the hole is a bezel. It just pops off and you replace it with the correct one. A drop of silicone to hold it in place. I think any of the folks that supply keys etc have them. Try Pete Lindahl.
                        • Gerald C.
                          • June 30, 1987
                          • 1321
                          Harry,
                          I've contacted a Doug Vogel and he's asking "Do you want one hole at thetop or bottom". I thought the ignition lock had only one hole option??
                          Jerry
                          • Joe R.
                            • July 31, 1976
                            • 4552
                            Duh,
                            Am I missing something? We are talking about a 63 aren't we?
                            When I get a chance I'll post a pic of a real 63 switch and tumbler set with a hole and key.
                            JR
                            • Gerald C.
                              • June 30, 1987
                              • 1321
                              Thanks Joe,
                              Yes it is for a 63.
                              Jerry
