65 Coupe Rear Blower hot wire - NCRS Discussion Boards
  • Doug M.
    • January 1, 1991
    • 68
    I understand from a John H. post that this connects to the dash heater control , on the " 4 o'clock" terminal, looking from
    the drivers position.
    My terminal has a tab in the middle at 90 degrees. Should this tab be straightened before attempting a connection?
    Thanks to any replies.
    Doug
  • Tom D.
    • September 30, 1981
    • 2134
    Re: 65 Coupe Rear Blower hot wire
    Original harness or repro?
    Repros should have instructions.
    Tom
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Don H.
      • December 1, 1981
      • 1487
      Doug, It connects to the blower switch because when the heater/AC blower is on, the power to the rear blower is off. You should be able to tell the proper terminal to connect to with a volt ohm meter. If you are asking if the bent terminal will interfere, you can make that call. I will be "into" mine in the next day or two and can check or possibly get a picture. Good luck, Don H.
      • James W.
        • December 1, 1990
        • 2658
        Don,
        I'd be interested in seeing that picture also as I am getting ready to start troubleshooting why the rear blower motor in my '65 coupe doesn't want to work.
        James West
        • Doug M.
          • January 1, 1991
          • 68
          Tom, Don, James,
          Original harness, not sure about switch. Will be back at this and report in a few days
          Doug
          • Doug M.
            • January 1, 1991
            • 68
            Doug
            OK, back at it today. The terminal with 90 degree tab on the heater control is specifically designed to accept the hot wire connector from
            rear blower. Self explanatory when you see them both together.
