69 sb distributor ignition shield- one piece or two piece? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1390
    Guys,
    Can anyone tell me whether the distributor ignition shield on a 69 sb typically came with a one piece or two piece cover? I believe I had the original cover when I disassembled my car and it was a two piece but I have also read and been told by some that the distributor covers on 69 sb were one piece. Thanks.
    Mike
    • 43221
    Re: 69 sb distributor ignition shield- one piece or two piece?
    Originally posted by Michael Leonard (46610)
    Guys,
    Mike
    Mike------
    My original owner 1969 built in mid September, 1969 has a two piece shield.
    • Russ S.
      • April 30, 1982
      • 2162
      All were two piece.
      • Jeffrey S.
        • May 31, 1988
        • 1882
        If you are talking about the box only around the distributor, my October '68 car has a 1 piece box. It is spot welded and does nor separate. The cover would be the second piece. I apologize if I read the OP wrong.
        Jeff
          • 15599
          Jeff
          It would be helpful for the latest update of the 1968-69 TIM&JG to have more input as to the change point from one-piece to two piece for small block.
          • Mike F.
            • April 25, 2011
            • 668
            1970 production started with a two piece box (plus lid), then transitioned to the one piece box (plus lid), then transitioned again to no box (just a lid).
            If this occurred in 1970 production, wouldn't all of 68 & 69 have had the two piece box (plus lid)?
              • 15599
              Mike
              That would be a logical assumption (and in fact it is what we have thought), but we have learned from past experience with other details where that kind of thinking gets us.
                • 43221
                Mike------
                I believe that 1968 and early 1969 used a shield that was one piece. In other words, the front and rear halves were permanently attached to each other. In fact, Jeff Salz has reported this for his 68 above.
                • Gary B.
                  • July 31, 1979
                  • 926
                  Hmmm, another thing to look at tomorrow.
                  Gary
                    • 15599
                    Gary
                    After lunch, or before?
                    • Gary B.
                      • July 31, 1979
                      • 926
                      After lunch.
                      Have to have a blown out 10-ply Michelin tire replaced in the morning. Second tire on a new truck with Michelins. Good thing I was going slow?
                      Gb
                        • 15599
                        After lunch.
                        Gb
                        Interesting tire story, and interesting day. Thanks for the fun. Much more fun than replacing the starter.
                          • 11643
                          After lunch.
                          Gb
                          Air pressure high enough?
                          Or just bad luck?
                          I discovered that LT tires take a lot more air pressure than P-rated tires in order to maintain their load rating. I now run 51psi or more vs 35 on P-rated truck tires; page 23 for my tires (though mine are not Toyo).
                          https://toyotires-1524598101.netdna-ssl.com/media/2125/application_of_load_inflation_tables_20170203.pdf
