1967 435 start/ wont keep running electrical ? - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    Just tried to start 67 435 car for the 1st time ( fresh restoration) the motor will fire and run ,but, it will only fire and run when the ignition switch is in the start position ( yes the starter is engaged ,so i cant run it for only a second ) any ideas ?
  • Jeffrey S.
    • April 1, 2004
    • 133
    Re: 1967 435 start/ wont keep running electrical ?
    The switch has run position internally , to keep the engine running once you let the key go. I would suspect the switch. hope this helps Jeff
    • Dino L.
      • February 1, 1996
      • 694
      Referencing the wiring schematic double check the ignition switch, starter and ballast resistor wiring. That would be my first place to look.
      Dino Lanno
      • John D.
        • June 30, 1991
        • 875
        No ballast on a 435 hp with TI...no ?
        • Paul S.
          • June 30, 1982
          • 359
          yes , no ballist
          thanks for the help so far
          • Joseph S.
            National Judging Chairman
            • March 1, 1985
            • 936
            Paul, Do you have a photo of the Pink wire that comes out of the firewall along with the wires for the wiper motor. This is the wire that feeds the ignition system once the key is back on the start location. I have seen this connection go bad several times.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11367
              Yes, either a bad IGN switch(Pink lead terminal) or as Joe says a open on the #12G Pink wire coming out of the firewall to the right of the wiper motor. This connects to the White(resistor) lead in the TI harness to power the TI module. With IGN ON, I'd put a voltmeter at both points to isolate the fault.
              The #12G Pink is supplying power to the TI module during RUN(IGN ON). If it only fires in START, the fault could also be a open circuit of the TI harness to the TI Module. If so, the resistor wire or the internally soldered connections inside the TI harness may be open.
              Either way, the symptom of it firing off in START is because during START, the Solenoid R terminal is supplying full cranking voltage to the TI module which bypasses the main feed from the #12G Pink IGN source. This is similar in design to the Points distributor ignition system which bypasses the Ballast Resistor during START.
              I should modify the CSM schematic below a bit more to show the "SOL R Terminal" actually being connected to BAT+ and a more detailed diagram of the "SWITCH"(Ignition Switch).
              • Paul S.
                • June 30, 1982
                • 359
                ok guys ,, thanks for the help
                I will be back on it tonight , so well see how things go
                • Paul S.
                  • June 30, 1982
                  • 359
                  Fixed it
                  was a bad connection on the ti harness plug at the firewall . Runs/starts fine
                  thanks for the help!!
