Please help me identify these small parts for my 68 - NCRS Discussion Boards
  • Michael M.
    • February 15, 2007
    • 455
    I recently did an exhaustive inventory of all of my spare/old and new parts. Of the hundreds of parts, I can't quite place where these go on my 68 (although I have an idea on some of them) and the car is in shop right now so I have no reference point. Any help is appreciated. Thanks.
    - Mike
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Please help me identify these small parts for my 68
    3rd photo spring clip most likely carburetor linkage or reverse light switch linkage on transmission
    4th photo brake block attach clip.
    5th photo steering box mount bolt
    6th photo headlight linkage pivot bolt
    • Michael M.
      • February 15, 2007
      • 455
      Thanks Paul! These all make sense. Hopefully, others can chime with the rest. The 2nd photo really has me stumped. It looks like a bushing retainer similar to the ones used on the leaf springs, but it's smaller.
      - Mike
      • Paul O.
        • August 31, 1990
        • 1716
        1st photo looks to be 1/2 of a engine bay hose clamp to inner fender skirt assembly.
        The other 2 not sure of what they are.
        • Michael M.
          • February 15, 2007
          • 455
          That first photo is some sort of retainer clip and although it spreads out similar to an engine bay hose clamp, it's not part of that assembly. I vaguely remember using them to retain some sort of rubber shield or something near the wheel wells. The last photo is, I think, part of the vacuum system possibly under the dash, but I can't be sure. It's a thick rubber block with 4 holes in it.
          - Mike
          • Edward C.
            • August 13, 2014
            • 152
            The 2nd photo looks like the cups that go on the end of the leaf spring for the links/bushings.
            • Anthony F.
              • February 7, 2014
              • 79
              Photo #2 looks familiar, might be a rear shock lower mount washer. Here are two links:
              https://www.paragoncorvette.com/p-35...ck-washer.aspx
              Buy your 1953-1982 Corvette Rear Shock Lower Mount Hardware at Zip, source for Corvette suspension components including front & rear shock components. (GM Part 3714310)
              • Michael M.
                • February 15, 2007
                • 455
                Anthony, yes, they could be the lower shock mount cups, although the raised lip on the back side makes me not 100% convinced. I may have to wait to get the car back for this one. Edward, definitely not the leaf spring bushing retainers as they are too small although of a similar design.
                Thanks for the ideas.
                - Mike
                • Leif A.
                  • August 31, 1997
                  • 3658
                  #2...how about front stabilizer link retainers??
                  Leif
                  • Edward C.
                    • August 13, 2014
                    • 152
                    That would have been my next guess, the link that connect the sway bar to the A arm. But the cup looks a little different on the front set, more rounded without the lip, or at least that's what I remember.
                    • Anthony F.
                      • February 7, 2014
                      • 79
                      I like a good mystery, so here is a link from Ecklers for a set of Bilstein HD shocks. One of the cups looks close:
                      I'm thinking maybe the cup design may differ based on the manufacturer.
                      I just redid the front stabilizer links on my car, the cups on the one's I used are close, but don't look exactly like the ones in your picture.
                      • Michael M.
                        • February 15, 2007
                        • 455
                        Thanks guys but these are too big (diameter) for end link bushing retainers. Of course, there's always the possibility that parts from another car got mixed in with my Corvette stuff. Maybe that's why no one can definitively identify. Let's see if others may have an idea.
                        - Mike
                        • John C.
                          • January 1, 2005
                          • 616
                          Mike
                          # 1 is a clip for holding the front bumper brace dust shield. 68 only part. You'll need more than one.
                          John
                          • Edward J.
                            • September 15, 2008
                            • 6960
                            Mike photo 4 looks like the door lock cylinder retainer?? and photo 7 looks like a spark plug wire loom? photo 2 looks like a front shock retainer it goes between the lower rubber and frame.
                            • Michael M.
                              • February 15, 2007
                              • 455
                              Thanks John, I knew it was related to some sort of rubber seal or cover. I have all I need, plus about 5 extras. Excellent work!
                              - Mike
