C-3 Brake Proportioning Valves - NCRS Discussion Boards
  • Lynn S.
    • November 1, 2004
    • 99
    Does anyone know if you can use a 1978-82 valve on a 1975 car? The only difference I see is the wire connector on the top of the valve. Are there different preasure settings in the two valves? Thanks.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C-3 Brake Proportioning Valves
    Contrary to their name, the pre-1978 valves have no 'proportioning' function. They are strictly a distribution manifold with an integral electrical switch that detects via a shuttle valve, unequal fluid pressure.
    Some (all?) '78 and up valves do have a proportioning function in addition to the above.
    There is no advantage to using a later valve on an earlier car, possibly some drawbacks.
