Hi all, Can someone post a picture of the return hose routing off the fuel pump to the hard line on the frame rail. The fitting on the fuel pump aims towards front of the car. 72 Ls5. Assembly manual does not show the rubber hose routing. Thanks Mike
72 ls5 fuel pump return hose
Tags: None
Re: 72 ls5 fuel pump return hose
Mike------
I can't post a picture but I can tell you that this application used a MOLDED "S" hose. You can get one from Dr. Rebuild.In Appreciation of John Hinckley- Top
The "s" hose is the 3/8" inlet hose. I am referring to the smaller return hose that comes off the front of the pump and connects the steel line on the frame rail. Thanks, Mike- Top
Thanks Tom, anything would help. Just want to route it correctly. Mike- Top
Still looking for a picture of how the rubber return hose is routed off the fuel pump to steel line on frame. 1972 ls5. Assembly manual shows for small block. Big block nipple is facing forward- Top
On my '70 LS5, I routed it with the largest radius bends possible while not touching anything. Naive maybe, but I didn't research it very much.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
