72 ls5 fuel pump return hose - NCRS Discussion Boards
  • Michael C.
    • May 3, 2015
    • 55
    Hi all, Can someone post a picture of the return hose routing off the fuel pump to the hard line on the frame rail. The fitting on the fuel pump aims towards front of the car. 72 Ls5. Assembly manual does not show the rubber hose routing. Thanks Mike
    • 43247
    Re: 72 ls5 fuel pump return hose
    Mike------
    I can't post a picture but I can tell you that this application used a MOLDED "S" hose. You can get one from Dr. Rebuild.
    • Michael C.
      • May 3, 2015
      • 55
      The "s" hose is the 3/8" inlet hose. I am referring to the smaller return hose that comes off the front of the pump and connects the steel line on the frame rail. Thanks, Mike
      • Tom L.
        • October 17, 2006
        • 1439
        Won't get to it tonight but I can get you a pic from mine if you want. Can't guarantee it's NCRS correct though : )
        • Michael C.
          • May 3, 2015
          • 55
          Thanks Tom, anything would help. Just want to route it correctly. Mike
          • Michael C.
            • May 3, 2015
            • 55
            Still looking for a picture of how the rubber return hose is routed off the fuel pump to steel line on frame. 1972 ls5. Assembly manual shows for small block. Big block nipple is facing forward
            • Mark E.
              • April 1, 1993
              • 4600
              On my '70 LS5, I routed it with the largest radius bends possible while not touching anything. Naive maybe, but I didn't research it very much.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
