55 engine stamping question - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    #31
    Re: 55 engine stamping question
    And then I remembered that I used to have an early 56 Flint 265 engine block ... and here is the engine stamp.
    Yes, the R was added after the fact, but note that the sequence numbers are individually stamped
    • Lynn L.
      1953-55 Team Leader
      • February 1, 2000
      • 162
      #32
      The #2 1955 corvette was sold at kissimmee mecum auction January of last year. No owner record at Proteam.
      The engine pad was a 009163F55FG with elevated first two 0s. This pad if we could get a clear picture would
      help with my pad approval Thanks
      • Dan A.
        • May 31, 1974
        • 1073
        #33
        Ed, when you say early may I ask what the casting date was?
        Also when you say the R was added after the fact, do you mean long after the engine build and stamp and use with only the G suffix?
        • Dan A.
          • May 31, 1974
          • 1073
          #34
          The first 5 characters of this '56 appear to me to have been in a holder.
          • Edward M.
            • November 1, 1985
            • 1922
            #35
            The date code for this engine was mid October, 1955 (I think it was the 17th).
            I bought the 56 Chevy this engine was in. The engine suffix at that time was F56G. I added the R after the machine shop confirmed the engine wasn't cracked.
            Date is way too early for a Corvette engine, what I wanted to do was play around with adding the R.
            • Edward M.
              • November 1, 1985
              • 1922
              #36
              I agree, a gang holder was used in this example for the first 5 digits of the sequence number.
              • Edward M.
                • November 1, 1985
                • 1922
                #37
                Going back to this engine, it might "appear" that the first five digits are in a gang holder, but look closer.
                The digit 2 following the second zero is cocked slightly to the right. The spacing between the top of the 2 and the zero is not the same as the spacing between the bottom of the 2 and the zero (it was easier to see on the actual engine).
                The 7 following the 2 is stamped higher that the other first 5 digits.
                The 9 following the 7 is spaced more toward the right than would be normal in a gang holder.
                I am going to go out on a limb and say that the first five digits were stamped by one person at the same time, and the last 2 digits were stamped later (and perhaps by a different person).
                • Lynn L.
                  1953-55 Team Leader
                  • February 1, 2000
                  • 162
                  #38
                  The #2 1955 corvette was sold at Mecum Florida auction last January, no owner known by PROTEAM.
                  The engine pad stamp has elevated first two 0s (0091603F55FG). Finding the owner and obtaining a
                  clear stamp pad pic would really support my cause. thanks Lynn
