Ignition Switch wiring Question - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    While attempting to install my gauge cluster I came upon a puzzle , several actually but one in particular .
    As you can see , I got M & H to install my original plastic ignition connector to their new wiring harness. As pictured the ignition switch has five prongs. At 12::00 we have IGN. then BAT. ,then SOL. then ACC. and lastly GRD.
    The connector has Double pink wires going to IGN......Red to BAT...... Purple to SOL....... and black to ACC . with nothing going to GRD.
    Could this be correct?
    Jim
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: Ignition Switch wiring Question
    Jim, You're good. The GND terminal is there on the switch but not used for Corvette. In fact I am unsure if that switch was used on other car models or not. If so, the GND terminal may have been used for them.
    Rich
    • Peter L.
      • May 31, 1983
      • 1930
      Rich - The GM Delco-Remy p/n 1116673 ignition switch (embossed w/673) was also used on the 1966 Chevrolet. Pete
      • Jim S.
        • March 1, 1986
        • 1408
        Rich
        Thank you Sir !
        Jim
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11363
          Thanks Pete. Do you know if used on the the 66 Pass cars, what the ground would be used for? I'd imagine it's a terminal just connected to the case of the switch.
          Originally posted by Jim Schwering (9598)
          Thank you Sir !
          Jim
          Your welcome Jim
