Too much engine oil maybe - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Using the dip stick as the guide; at what point over the fill line would be to much oil in the crank case? 1/2", 3/4", 1", etc, etc?
    '72 - 350 block.
  • Edward J.
    • September 15, 2008
    • 6940
    Re: Too much engine oil maybe
    Jerome, I really don't think you find some one has documented the dip stick over full. as most know that most older corvettes were 5 qts. and some higher H/P engine were 6. If you over fill a crankcase it advisable to drain. If you changed your oil and added 5 qts. and it reads slightly above the full mark, not to worry, sometimes we tend to not let it drain every drop out.
    • Larry M.
      • December 31, 1991
      • 2688
      I would measure the dipstick distance between ADD and FULL. This is generally 1 QT. I have run many of my cars at 1 QT over FULL to make certain I had enough oil in the pan at high RPMs...............so I would say 1 QT over FULL should not be a problem.
      If more than this, I would probably drain some out, or replace the oil filter to remove some of the excess oil.
      Larry
      • Harry S.
        • July 31, 2002
        • 5259
        I can't recall when spin-off oil filters started but did you convert from a canister to a spin-off?
        Harry
        • Larry M.
          • December 31, 1991
          • 2688
          Harry
          I believe the change generally occurred in 1968.............exceptions being some police and taxi engines which retained the steel canister filter for a few more years.
          Larry
          • Jim T.
            • February 28, 1993
            • 5351
            My original 327/350 came with the spin on filter and was built Feb 1968.
