1958 bumperette vs 1961 bumperette - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    What is the difference between the bumperette for a 58,59,60 and a 61/62. Central corvette shows two different part numbers.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1958 bumperette vs 1961 bumperette
    The length of the braces/brackets under the car.
    • Brandon T.
      • October 23, 2008
      • 872
      I found a set off a 62 but I have a 58. Thanks for the information. I don't guess I will buy them and keep looking for a set for a 58-60.
      • Jim L.
        • September 30, 1979
        • 1816
        You are asking about the front bumpers, I assume.
        There is a mount bracket for the grill bar welded to the interior of the bumpers. This bracket is farther forward on 61/62 bumpers than it is on 60 and earlier bumpers. If you mount 61/62 bumpers on an earlier car, the grill and grill teeth will protrude beyond the grill surround chrome.
        • Frank D.
          • December 27, 2007
          • 2703
          If the earlier bumperette brackets are mounted on the later (61/62) C1s you'll see the difference pretty dramatically - they will be too far forward and down. The first picture shows this. The second picture is with the correct brackets on a 61, you should just be able to get a fingertip between the center bar and the top of the bumperette.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11334
            Right......Some visuals for reference.
            Bumperette bracket differences. I can't remember if these are 58-60 or 61-62, but IIRC 58-60 is about a inch longer than the 61-62.
            61-62 bracket is shorter than the 58-60 bracket to get the bumperettes closer to the grille bar.
            This is what a 61-62 looks like if you use the longer(wrong) lower brackets. Compare to Frank's photo of the correct length(shorter) on his 61.
            58-60 longer to clear the teeth. If you use the shorter 61-62 brackets, the backside of each bumperette will hit two teeth.
            Bumper differences.
            • Brandon T.
              • October 23, 2008
              • 872
              Do you think a 23 1/4 bracket is for a 58? The guy wanting to sell a set sent me a pic of one of his brackets and it measures 23 1/4. Do you think yours is off a 61 or 62?
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11334
                Brandon, I have a loose set and a mounted set on my 59. I'll get back to you (soon) with the dimensions of, at least my 59 brackets.
                Rich
