1970 Carpet Install: Seatbelt Cutout - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 210
    Installing carpet on a 1970 and do not have original carpet to copy. To install the seatbelts, do you cut a slit on the carpet on each side of the seat? Thanks if anyone can describe or provide photos.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Mark E.
    • April 1, 1993
    • 4603
    Re: 1970 Carpet Install: Seatbelt Cutout
    A hole is needed for each bolt. Cutting an "X" works well. Preinstall the carpet, then poke a hole with an awl to mark the spot.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • William H.
      • January 1, 2006
      • 210
      Thanks, Mark. Makes sense.
      Bill Hyndman
      • Jim T.
        • March 1, 1993
        • 5351
        William since you said you do not have your 1970's original carpet I will mention how the carpet in my original owner 1970 with it's original carpet covers the two front mounting bolts for the seat tracks. The carpet is cut about the width of the front seat track so you have to lift the carpet pieces covering the attachment bolts and fold it towards the front of the car to see the bolts. The cut carpeting covers the front seat tracks. The two rear seat track bolts can be seen when the seat is moved forward. The seat track at the rear bolt positions is on top of the carpet and the bolts are visible going through the seat tracks.
        • Mike E.
          • February 28, 1975
          • 5141
          My 2nd-owner 70 is the same. I'm pretty sure that is what the new 70-72 JG says also.
            • 15621
            That is the way my original owner 1970 is also. The 1970-72 TIM&JG has pictures of the carpet cut-outs. If you get the color version you will notice a Bright Blue carpet photo that is very familiar to me.
            • Kenneth B.
              • August 31, 1984
              • 2091
              Mine is also the same VIN 7601 Original carpet.
              • Leif A.
                • August 31, 1997
                • 3646
                I thought the OP was asking about seat belt installation, not seat track installation. I only wish I could answer his original question but I haven't owned my C3 since 1996.
                Leif
                  • 15621
                  My seat belt fasteners just pass through holes in the carpet, just like Mark E said in post #2. No pictures of that. The seat would have to be out to get pictures of those bolts.
