1965 Pad Stamp Help - NCRS Discussion Boards
1965 Pad Stamp Help
  • Erv M.
    • February 21, 2007
    • 445
    1965 Pad Stamp Help
    Does it look ok? 1965 327/300 4 speed convertible
    Trim Tag has I15 for an assembled date
    VIN is 194675S115991
  • Jim S.
    • March 13, 2013
    • 360
    Re: 1965 Pad Stamp Help
    Body build date (AO Smith) April 15
    Engine assembly date April 19
    Final assembly April 24
    However, suffix HE is a 250hp, not 300hp. 300hp would be HF.
      • 6957
      Erv, I am not a expert but broaching good as does the vin and suffix. Jim good catch its a HE 250 hp
      • Erv M.
        • February 21, 2007
        • 445
        Are you guys sure about the HE suffix. I do not have a 65 Judging Manual buy internet shows it as a 327 @ 300hp??????
        • Jim D.
          • 2885
          100% sure. "HE" is a 250HP.
            • 6957
            Erv, if you have a Corvette black book,take a look engine codes are listed. Erv I seen where the owner(s) were told what he thought the engine was, yet some will do some minor mods such as valve cover decals to appear as such.
            • Jim S.
              • March 13, 2013
              • 360
              Check which carb you have.
              HE 250hp has a WCFB carb Casting # Main body 0-1465 Air horn 6-1672
              and a HF 300hp has a AFB carb Casting # Main body 0-1552 Air horn 6-1518
              • Steven B.
                • April 11, 2012
                • 233
                They must have changed the hp indicated by the suffix HE in 1966 and 1967, because a '67 HE is a 300hp and they didn't offer a 250hp engine in '66. Did HE refer to the base engine whatever it was in a particular year? I like the pad, by the way.
                Steve
                • Jim D.
                  • 2885
                  Steve, "HE" indicates a base engine with manual trans. for years 65-68. For all years except 65, which was 250HP, it was a 300HP engine.
