Exhaust Manifold bolt finish - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1304
    I will be refinishing my 1967 small block exhaust manifolds this winter. I put new bolts on about two years ago and they have rusted already.
    Does anyone have any thoughts as to what finish I should try for so that these bolts do not rust.
    Thanks!
    Jerry
    • 43259
    Re: Exhaust Manifold bolt finish
    Thanks!
    Jerry
    Jerry-------
    The bolts were phosphate-finished. In the exhaust manifold application they will rust rapidly, just as you've found. While I have not done this, I expect that a very high temperature satin clear might be the best bet to prevent this from occurring while maintaining close to original appearance.
    • Gerald C.
      • June 30, 1987
      • 1304
      Thanks Joe!
      • Bill L.
        • February 1, 2004
        • 1403
        Jerry-------
        VHT has a 1200 degree satin clear paint. Once properly torqued, you can spray some clear on a piece of shiny cardboard and use a brush to touch up.
        Bill
        • Edward J.
          • September 15, 2008
          • 6950
          Thanks!
          Jerry
          Jerry, the exhaust manifolds and bolts, French locks where painted engine orange on your 63, as these parts where on the engine during the painting process.
