1994 LT1 power steering pulley wobbly - NCRS Discussion Boards
  • Jim P.
    • February 25, 2010
    • 58
    My power steering pulley is wobbly and I was looking to replace it. The part is discontinued and I can only find one on ebay for $250. GM Part No. 10227069. Is there any other gm part that will replace this. ANY OTHER IDEAS ON A REPAIR OR REPLACEMENT? This is just a daily driver and it seems my only other option is an aftermarket replacement - Billet Specialties FM1035PC - 6-Groove Power Steering Pulley.
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: 1994 LT1 power steering pulley wobbly
    Give these two a call. They maybe able to help you out.
    Specializing in C4 Corvette parts to restore your Vette!
    The area's largest used parts and accessories salvage yard for Corvettes and late model Chevy Camaros, GTOs, Impala SS, Trailblazer SS, Pontiac Firebirds, and Cadillac CTS-V.
    • Kenneth P.
      • November 17, 2015
      • 151
      Ok I found this on eBay $99 is better then $249 and you get the pump to. You can make them an offer.
      Ken
      • Kenneth P.
        • November 17, 2015
        • 151
        Here is another one I found on eBay. You can see the pulley part number in the pic.
        Ken
        • Jim P.
          • February 25, 2010
          • 58
          Thanks Ken. I guess I need to improve my search skills. I was able to actually purchase one here in Houston for Carney's Corvette with the pump. His advise was not to pull it from the pump, as that is how it gets bent. So I am reinstalling the new used pulley with the pump hopefully it won't wobble.
          Thanks again.
          • Kenneth P.
            • November 17, 2015
            • 151
            Good to hear. I like searching for stuff it keeps my mind sharp.
            Ken
              • 43222
              Thanks again.
              Jim------
              They get bent only if a proper puller is not used to remove the pulley.
              • Keith B.
                • September 15, 2014
                • 1583
                Thanks again.
                they also get bent when removing the water pump bolt and not watching how fare out your ratchet is moving before it gets to the pulley if you don't go though the one hole. Don't ask me how I know... its been bent for nine years with no ill effects
