C2 Exhaust Extension Tips GM 3819573 - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Can someone tell me how these LI Corvette extensions fit the 1963 heat shields and judge. I am aware the originals were magnetic and had a seam at 5-7 o'clock position and are a very thin gauge stainless.
    I have some reproduction tips that I can't get inside the heat shield, I can't recall the gauge but will check later. I appreciate any input on these shields or a source for two nice originals.
    TIA, Tim
  • Harry S.
    • July 31, 2002
    • 5299
    Re: C2 Exhaust Extension Tips GM 3819573
    Tim, I have a set of LIC extensions and a set of LIC heat shields on one of the 63's. They all fit fine and look good. Was judged at the National this year with no deductions.
    Just remembered, I have one NOS heat shield and the LIC shield is the same thickness.
    • Gary B.
      • February 1, 1997
      • 7022
      Tim, Harry,
      Is the heat shield you're talking about the same as the bezel that goes thru the rear valance panel?
      Gary
      • Harry S.
        • July 31, 2002
        • 5299
        Originally posted by Gary Beaupre (28818)
        Tim, Harry,
        Gary
        No, it's a 63 only shield. I'll see if I can dig up a picture.
        This is an LIC picture, need to give them credit.
        • Gary B.
          • February 1, 1997
          • 7022
          Harry,
          Thanks for the education. I'm not familiar with some of the '63 unique items.
          Gary
          • Timothy B.
            • April 30, 1983
            • 5186
            Thanks Harry, I think the heat shields I bought were from corvette central but I will check the ID and post and I would appreciate you comparing against the LI Corvette part. If it's the same, I will just order the extension tip. Does the tip also have the seam and how thick is the stainless?
            • Harry S.
              • July 31, 2002
              • 5299
              Yes it has a seam. As I recall the original was .025 thick. The LIC is .045 thick. The LIC is a bit thicker but not as thick as the old repro's that were as thick as a frying pan.
              You want the one without the part number stamped on it.
              33-40 Tail Pipe Extensions(pr)(magnetic With Seam,no#) +-View
              63-7 1 PR Pair
              $59.00
              • Timothy B.
                • April 30, 1983
                • 5186
                Harry,
                I appreciate your help, I have one more question if you have one of the LI Corvette tips handy. What is the OD of the tip where it slides into the heat shield. I am trying to figure out if the heat shields I have are large enough.
                Thanks again, Tim
                • Harry S.
                  • July 31, 2002
                  • 5299
                  Tim, sorry, not available.
                  • Timothy B.
                    • April 30, 1983
                    • 5186
                    Thanks Harry, I will try to find out from LI Corvette.
