How do I mount the starter solenoid heat shield? - NCRS Discussion Boards
  • Paul S.
    • October 29, 2015
    • 203
    Hi all,
    Looking for a little help...
    The 1108338 starter on my '69 base convertible was missing the solenoid heat shield. I recently found and cleaned-up an original one (shown below), but I can't figure out how it is supposed to be mounted to the starter solenoid. I cannot find anywhere in the AIM where this is shown clearly, so I am wondering if anyone has a photo or can try to explain it to me.
    Here is the heat shield:
    Thanks in advance,
    Paul
  • Hank D.
    • January 1, 1999
    • 138
    Re: How do I mount the starter solenoid heat shield?
    Originally posted by Paul Shatlock (61745)
    Hi all,
    Thanks in advance,
    Paul
    I'm a C2 guy, so here's a diagram out of the '64 AIM. Hope it helps.
    • Ed S.
      • August 6, 2014
      • 1390
      Paul - when you install the shields if you don't have a battery shut-off switch definitely disconnect the batt cables. Close quarters down there.
      Ed
      • Jeffrey S.
        • May 31, 1988
        • 1902
        Paul,
        UPC 6 sheet B2 shows the mounting. One screw attaches to the middle of the starter brace and the lower hole in the heat shield attaches to the brace mounting stud. I think the configuration of the shield in the photo differs from the configuration in the AIM. Are you sure that this shield is from a '69 small block? I will try to take a photo of mine over the weekend.
        Jeff
        • Paul S.
          • October 29, 2015
          • 203
          Thanks, guys -- this is very helpful!
          Jeffrey: I checked out the page in the '69 AIM that you mentioned... sure enough, it is there! Don't know how I missed that. If you can take a photo of your heat shield, I would greatly appreciate it. The one I bought is supposedly from a '69 small block, but it certainly could be incorrect, as I have seen a couple similar but different versions of the shield. Perhaps mine is from another year or engine configuration.
          Thanks again,
          Paul
          • Jeffrey S.
            • May 31, 1988
            • 1902
            Paul,
            Here are the photos of my '69. Hope this helps.
            Jeff
            • Paul S.
              • October 29, 2015
              • 203
              Originally posted by Jeffrey Salz (13182)
              Paul,
              Jeff
              Thanks again, Jeff -- that helps immensely! I see exactly how it mounts now. I really appreciate you taking those photos for me.
              - Paul
