Muncie rebuild kit - NCRS Discussion Boards
Muncie rebuild kit
  • Bob W.
    • December 1, 1977
    • 803
    Muncie rebuild kit
    Who sells the best and most complete Muncie 4- speed rebuild kit?
    Thanks Bob
  • Michael M.
    • February 7, 2011
    • 186
    Re: Muncie rebuild kit
    There are several sources for rebuild kits and they are probably all relatively complete. I would recommend getting the best quality bearings available as sources have changed over time.
    I bought my Muncie rebuild kit back in 2010 from D&L Transmission, Hunt Station, NY. Larry was great to work with and responded quickly when I found I needed additional gears. I've got six years worth of driving on mine since the rebuild without a problem and no leaks.
      • 43273
      I bought my Muncie rebuild kit back in 2010 from D&L Transmission, Hunt Station, NY. Larry was great to work with and responded quickly when I found I needed additional gears. I've got six years worth of driving on mine since the rebuild without a problem.
      Michael and Bob------
      I highly recommend Larry Fischer at D&L Transmissions for transmission parts.
      • Bob W.
        • December 1, 1977
        • 803
        Mike-Joe Thank for the quick reply.
        Bob
        • Stuart F.
          • August 31, 1996
          • 4676
          Did anyone who rebuilt a Muncie have case wear at the thrust ends of the counter shaft gear set? The tranny in my 63 July build is getting a little whiney in 1st, 2nd and 3rd so I assume that's the problem as I run a tall 3:36 rear. Back in the day, my friends would weld up the thrust washers even in the T10 cast iron cases from long wind outs (they welded themselves to the case over time). I have about 47k on mine now without ever a tear down or removal (same with the clutch).
          Stu Fox
          • Joe R.
            • July 31, 1976
            • 4552
            Stu,
            The fix for the Muncie countershaft is to machine and sleeve the case. Most machine shops and some of the larger transmission shops perform that service. Or just change out the case if you can find one.
            JR
            • Stuart F.
              • August 31, 1996
              • 4676
              Thanks Joe.
              Stu Fox
              • Chester C.
                • May 29, 2013
                • 154
                I've yet to own a BW or Muncie that did not leak there. Even with a sleeve, I believe it still would leak. Most guys just put some sealer on the end of the shaft and let the bell housing cover it.
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  Would that be the case no matter which gear lube you used? Back in the early 90's when I was recovering from open heart, I had a local Corvette full service dealer do some maintenance on my 63 and he changed the tranny gear lube using the new (at the time) spec light weight lube. My transmission began leaking in a number of places. Because of that, I soon as I was able, I checked the level and found it low and I sucked some out and noticed it was of a light weight viscosity so I drew most of it out and replaced it with 80/90 wt. gear lube (?). That seemed to improve it, but it still showed seepage at the bell housing and drips into my catch pan. It is probably, as you say, from the counter shaft end.
                  Stu Fox
                    • 43273
                    Stu Fox
                    Stu------
                    Leaks can also occur due to worn threads in the bolt holes for the bearing retainer. Sealer should always be applied to these bolts.
                    • John M.
                      • January 1, 1998
                      • 813
                      Stu,
                      you can check the countershaft end play by taking the side cover off and moving the shaft with a dial indicator on one of the gears. It's clumsy but you can do it. Too much play and you can spin the thrust washer messing up the boss. Check the shop manual. You don't have many miles on that tranny so I think you'll find it's ok. If it clunks in reverse it's trouble (I know.)
                      • Stuart F.
                        • August 31, 1996
                        • 4676
                        No trouble in reverse. It just sounds like it has straight tooth gears when I run low speed in 1st or 2nd through my village. What was they called that box? What ever it was, mine ain't one of those.
                        Thanks for the info though.
                        Stu Fox
                        • John M.
                          • January 1, 1998
                          • 813
                          Stu,
                          • Joe R.
                            • May 31, 2006
                            • 1822
                            Stu,
                            I think you're referring to the M22 "rock crusher" transmission.
                            Joe
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              That's the one Joe. How could I forget. Old age I guess (good excuse).
                              Stu Fox
