67 390HP Air Cleaner vent Tube - Replacement needed - NCRS Discussion Boards
  • Daniel E.
    • April 30, 2005
    • 145
    All,
    I need a replacement vent tube that is spot welded into the base of my air cleaner. It is a 427 390HP base. I vaguely remember someone advertising an exact replacement (ie the correct end configuration) in the driveline, but I can't seem to find the advertisement.
    This is the vent tube I'm looking for (someone smashed the backside of the tube):
    Daniel
    • 6942
    Re: 67 390HP Air Cleaner vent Tube - Replacement needed
    Dan, not sure if the email is still good, inq@argenparts.com give it a try his name is Ron Lovelace.
    • Daniel E.
      • April 30, 2005
      • 145
      Thank you, I'll give it a try and report back with the results
