did non hardtop ordered cars have the deck lid holes and side bolt holes??? - NCRS Discussion Boards
  • Michael F.
    • 745
    thanks question for another owner
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Dan A.
    • May 31, 1974
    • 1073
    Re: did non hardtop ordered cars have the deck lid holes and side bolt holes???
    Nope, they didn't.
    • Loren L.
      • April 30, 1976
      • 4104
      I have learned over the past 40 years Daniel, that you are supposed to find a way to say that "gently". Unfortunately, I've found it hard to do so and eliminate the 2 week time period wasted during the explanation process. The two weeks doesn't change the answer - except perhaps at various auctions..............
      • Dan D.
        • September 5, 2013
        • 181
        My '72 did not. My solution for attaching a 1971 top: The top had long threaded bolts in the rear corners (I don't know if that's the way it was originally) anyway I removed them and used the push pins designed for convertible tops. My top had a center pin. Since my car isn't a show car, I removed the pin and attached a small triangular gasket to the plate rather than drilling and installing the rear center plate. (I couldn't find one anyway) I then drilled and installed the side bolts. I didn't bother to measure...I put the top on first and drilled the holes. I bought the hardware from either Mid America or Eckler...I did this about 15 years ago and at my age...memory can be a problem. Anyway it wasn't a problem finding all necessary hardware and weather-stripping. Good luck on your project. For what it's worth...from start to finish I ended up with just short of 3 Gs invested in the prettiest garage ornament you could have...But, I'm not sorry and I wouldn't part with it.
        • Edward B.
          • January 1, 1988
          • 537
          Good work, Daniel, for giving a straight, understandable answer. We've all had enough of political correctness and couching responses in such a way to avoid offending anyone who has grown up in today's hypersensitive environment.
          • Kenneth B.
            • August 31, 1984
            • 2091
            My 65 original paint soft top only has no holes in the top of the deck or the threaded inserts on the side.
            • Kenneth F.
              • September 30, 1988
              • 284
              Michael, I bought my 1966 in 1967. It has a soft top only, but has the holes for the hardtop. I figured the seller was holding on to the hardtop and I offered to purchase it. He said he never had a hardtop for the car, and that he took delivery of the car at the factory. I suppose it could have been mistakenly drilled for a hardtop.
              Ken
