1954 Hubcaps - NCRS Discussion Boards
1954 Hubcaps
+ More Options
Posts
  • John S.
    • January 1, 2013
    • 22
    1954 Hubcaps
    Has any of the owners of 54s had a issue with continuios loosening of hubcaps. Mine begin with rotating slightly and bending the valve stems.Than if the problem is not addressed quickly, they will come off. I have the wheels with the nubs however that doesn't seem to help. Any one have a cure?
  • Jim L.
    • September 30, 1979
    • 1817
    Re: 1954 Hubcaps
    The problem of the wheel cover auto-rotating slightly isn't unique to '54s. The wheel covers on my '60 do the same thing. I have no idea why it happens. I just bite the bullet and reposition the covers every so often.
    Jim
    • John S.
      • January 1, 2013
      • 22
      Re: 1954 Hubcaps
      Thanks Jim! I'll keep trying to find a fix
      • Willard M.
        • August 31, 1979
        • 422
        Re: 1954 Hubcaps
        While my 54's never had this issue I remember a 62 that did. If I recall I bent the tabs ever so slightly so that there was a more aggressive hold on the wheel. The hubcap went on with more effort but that solved the issue for me. Hope that helps.
        • John S.
          • January 1, 2013
          • 22
          Re: 1954 Hubcaps
          Thanks Willard. I'll give that a try
          • Keith T.
            Infrequent User
            • April 30, 1993
            • 14
            Re: 1954 Hubcaps
            John, I read your post from over a year ago. I had exactly same problem on my 55 and installed steel valve stems which solved the problem. They wonโ€™t bend like rubber stems and prevent the cover from rotating.
            • Mike M.
              • May 31, 1974
              • 8411
              Re: 1954 Hubcaps
              I smear a slight amount of valve lapping compound of the nubs to increase adhesion. mike
