65 tachometer date stamp - NCRS Discussion Boards
  • Daniel D.
    • December 9, 2009
    • 112
    Is there any chance that this tachometer with the rubber date stamp of 2522 (see photo) is the original tach for my 2/8/65 built 65? The dating systems are sometimes a bit cryptic. Maybe the 22 is the 22nd
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 65 tachometer date stamp
    Dan,
    When tachs or speedometers are rebuilt more than likely the frame has to be replaced because of bearing wear! So the reproduction or replacement frame will have no numbers. If you request that the frame is used with that number, only the bearing will be replaced and the number will be saved.
    JR
    • Daniel D.
      • December 9, 2009
      • 112
      Thanks JR. Since it sounds like that stamp isn't critical, I'll send this one off the be rebuilt so that I'll have it ready to replace the current tach which doesn't work properly either. Do you or others have a prefered vendor for rebuilding? I've seen a few listed in Driveline.
      • Bob W.
        • December 1, 1977
        • 803
        Dan Joe is one of the vendors in the Driveline. Nice guy give him a call 501-834-1237.
        Bob
        • Brian T.
          • September 30, 1990
          • 190
          What you are reading is the last 4 digits of the part number of the tachometer assembly. Full part number is 6412522 which is a 6000 redline tach!
          • Joe R.
            • July 31, 1976
            • 4552
            Dan,
            A complete tach all new is just $175.00 plus shipping. Save the old one and just call and pay shipping in just one direction.
            JR
            • Daniel D.
              • December 9, 2009
              • 112
              Ah ha, that makes much more sense. Thanks.
              • Daniel D.
                • December 9, 2009
                • 112
                Thanks. Will do.
