Oiler cups - NCRS Discussion Boards
Oiler cups
  • Nicholas L.
    • November 1, 1982
    • 342
    Oiler cups
    Does anyone have a source for the oiler cups used on the generator and distributor for a 1960 Corvette! Thanks.
  • Mike M.
    • May 31, 1974
    • 8404
    Re: Oiler cups
    i believe i got some from corvette central. mike
    • Bob W.
      • December 1, 1977
      • 802
      Re: Oiler cups
      Nick Mike might be right I know that Corvette Central sell the tube and flapper for the 891 distributor.
      Bob
      • Pat H.
        • December 1, 1996
        • 420
        Re: Oiler cups
        I got mine from Corvette Central. They are functionally okay, but the real ones have Glit or Gilt Mfg stamped into the cap. The CC ones only have a circle with a "G" in the center. I don't think the markings are correct. I also understand that some of these caps were plain. I'm not sure who the expert is on these, but that's what I've been told on the judging field.
        • Mike E.
          • February 28, 1975
          • 5141
          Re: Oiler cups
          Gits was the brand name. Generally only one (or neither) had the gits id-- the od of the shoulder differed between the cup on some of the front frames vs the one on the rear. I don't recall whether that was aluminum frame vs. cast iron, or what it was exactly. I will try to get pictures tomorrow.
          • Mike E.
            • February 28, 1975
            • 5141
            Re: Oiler cups
            Here are pictures: the first two are original GITS and non-GITS caps, then a picture of a later incorrect GITS cap. The fourth is a 57-58 style of cap with a crowned area, and the sixth shows the different ODs of the bottoms. The sixth is a volunteer picture--same piece as picture number 1.
            • Nicholas L.
              • November 1, 1982
              • 342
              Re: Oiler cups
              Thanks for the pictures.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11356
                Re: Oiler cups
                Awesome photos Mike !!!
                For reference, the Front is small OD, the Rear is larger OD. Some repros have a "S", which I'm not aware were on C1 generators.
                Some electric shops may have some old end frames lying around that may have usable caps. Problem is removing them without damage. I ruined a few in the past. Maybe CRC freeze-off spray next time.
                Rich
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  Re: Oiler cups
                  I can tell you another place they were commonly used. Gitts caps came in a few sizes and were used as gas caps for old model airplane tanks that were mounted to the back of the engine. There are dozens on engines in my collection. I have also seen them used on industrial equipment. I didn't think they were that hard to find. They were also used on electric motors. Should be some out there, I didn't have to much trouble finding them the last time I bought some, BUT that was 2008.
                  Dom
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Re: Oiler cups
                    By the way, Gitts is still making them if you Google them.
                    Dom
