New Lifts - NCRS Discussion Boards
New Lifts
  • Frank K.
    • January 1, 2000
    • 319
    New Lifts
    Has anyone had any experiences with these new Quick Jack portable lifts?
  • Vinnie P.
    Editor NCRS Restorer Magazine
    • May 31, 1990
    • 1567
    Re: New Lifts
    Purchased one at Carlisle, easy assembly and after some initial sequencing, works great. Good service from the company via phone too.
    • Michael J.
      • January 27, 2009
      • 7122
      Re: New Lifts
      Are you supposed to trust those things as you lie and work underneath them.......?
      • Frank K.
        • January 1, 2000
        • 319
        Re: New Lifts
        What model? Sequencing the lift? Are all manufactures using the same components? Thanks Frank
        • Vinnie P.
          • May 31, 1990
          • 1567
          Re: New Lifts
          this is the 5000 lb model. took a few tries to get both sides to go up & down at the same time (sequencing) Can't answer your question about components...this one is very well made
          • Gene M.
            • April 1, 1985
            • 4232
            Re: New Lifts
            You can only die once, no second chance.
            I would NOT trust getting under that.
            • Mark E.
              • April 1, 1993
              • 4555
              Re: New Lifts
              Why do you say that?
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Mark E.
                • April 1, 1993
                • 4555
                Re: New Lifts
                That's good to hear. I'm getting too old and grumpy for the floor jack and stand dance, so I'm in the market for a lift that gets out of the way when not in use (unlike a two post lift), provides clear access to the chassis, is quick and easy to raise/lower, and unloads the suspension to enable wheel removal for service (unlike a four post lift).
                Vinnie's QuickJack and BendPak's MDS-6K (below) are on my short list. Other suggestions?
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Gene M.
                  • April 1, 1985
                  • 4232
                  Re: New Lifts
                  It looks very easy to rack the whole thing over from the side. Nothing tying one side to the other. Only sheet metal in picture shows a narrow stance. I'm just saying from the standpoint of my own life, not putting one's self in an avoidable situation. Just MHO.
                  • Mark T.
                    • March 1, 2004
                    • 199
                    Re: New Lifts
                    Mark the Bendpak lift you show has to be bolted down and takes a lot of floor space
                    Take a look at a portable scissor lift they use 110 volt power and they have numerous safety locks.
                    You can park over it when not in use, most brands will go from 48 to 52 inches high
                    Check out Qualitylifts.com that is the brand I sell It is the same company as Challenger lifts in Louisville KY and they have National distribution
                    • Mark E.
                      • April 1, 1993
                      • 4555
                      Re: New Lifts
                      Was this video inspired by you? https://www.youtube.com/watch?v=2ea-5ifRRYI
                      Dramatic, but I wanted to see what happens if the load is jiggled a bit to simulate bumping the car.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Mark E.
                        • April 1, 1993
                        • 4555
                        Re: New Lifts
                        Thanks Mark. I didn't realize the Bendpak needed to be secured to the floor. That may not be a deal breaker if I can park over it without too much drama. But a more portable lift better fits my needs.
                        The only scissors type lift I saw on QualityLifts.com is the QMR6 Mid-Rise. From its photo it looks like under car access is severely restricted. So maybe this lift is best suited for work that doesn't require getting under the car?
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Mark T.
                          • March 1, 2004
                          • 199
                          Re: New Lifts
                          Mark you are correct the scissor lifts have limited access to the center of the car. You can do oil changes and wheel service and chassis work
                          The Bendpak lift is a drive over lift but will give you center access to the car. The tire dealers like this style of lift for quick tire installation
                          I don't remember if the Bendpak is 110 volt or 220 volt
                          Mark
                            • 3416
                            Re: New Lifts
                            Hi Frank,
                            Santa brought me a Quick-Jack last Christmas.
                            I use it constantly and find it to be very stable.
                            There are 2 heights at which the locking bars can be set so that the frames are supporting the load and not the hydraulic cylinders.
                            It's really simplified getting under the car for me. At the lower lock height I work off the floor and at the higher lock height I work off a creeper.
                            The height in my garage is limited, so a 2 or 4 post lift wasn't ever an option.
                              • 11644
                              Re: New Lifts
                              I've also looked at the MaxJax as an option for a lift that can be moved out of the way when not in use.
