'66 427 with AC Battery Ground Cable Bolt Headmark? - NCRS Discussion Boards
  • Mike B.
    • July 31, 1994
    • 843
    Hi Guys,
    Could anyone chime in who has an original 427 AC car concerning the short ground cable engine attachment? The '66 AIM, UPC C60, sheet E3 shows this cable attached by one of the driver's side bellhousing bolts. Is that what you are seeing? Any originals with a standard flat hex head bolt and lock washer there?
    Through research I feel this bolt was zinc or cad plated, flat head, grade 2 (no lines) with headmark "RBW" with a single raised dot. I found this bolt on the car in a different (wrong) location that "bubbuh" had moved and I'd like to put it back to it's correct location.
    My '66 had a scatter shield installed with aftermarket cables/hardware when I bought her way back when. Any help here would be greatly appreciated!
    Mike
  • Joe R.
    • July 31, 1976
    • 4551
    Re: '66 427 with AC Battery Ground Cable Bolt Headmark?
    Refer to the Similar Threads below as the question was answered by John Hinkley in a previous thread.
    JR
    • Mike B.
      • July 31, 1994
      • 843
      Thanks for the reply Joe. I read those posts. I've seen a couple AC BB cars with a flat head bolt installed there vs. the existing bellhousing bolt application.
      Anyone out there have a unmolested original '66 or '67 Big Block AC car? Could someone post some shots of their attaching bolt for the battery ground cable? Or a shot during disassembly? I'd like to see what your cars had installed.
      Thanks again. Mike
