Scan Tool - NCRS Discussion Boards
Scan Tool
  • Frank K.
    • January 1, 2000
    • 319
    Scan Tool
    Where can one find for purchase a scan tool for a OB1 car? (1993)
  • Mark E.
    • April 1, 1993
    • 4584
    Re: Scan Tool
    The last time I checked (a few years ago), many new scanners had OBI and OBII adapters and capability.
    I wouldn't be surprised if today fewer supported OBI as that technology gets older, but you might check.
    Plan B may be a used one.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • James G.
      • May 31, 1976
      • 1556
      Re: Scan Tool
      SNAP ON TOOLS always sold them in the 80's and 90's. CAR QUEST AUTO also should have them.
      • Joe R.
        • July 31, 1976
        • 4551
        Re: Scan Tool
        NAPA, ORileys, Carquest, Autozone any major automobile parts supplier will have them.
        Don't use Snap On as they value their tools at about ten times the going price.
        JR
        • Larry M.
          • January 1, 1992
          • 2696
          Re: Scan Tool
          Here is one from Actron. CP9001. New.
          Ebay will likely have some earlier model used ones.
          Larry
            • 11651
            Re: Scan Tool
            I bought one that connects to my laptop, and one that connects to my iPad via Bluetooth. The pair (Amazon, I believe) was cheaper than buying one tool locally. I've used them on a couple of cars now, and they work great.
            • Keith B.
              • September 15, 2014
              • 1584
              Re: Scan Tool
              JR
              Your going to have to buy a used Snap On scanner to use on a OBD1 and OBD2. The one I use is about 20 years old but works very well. I have tried to use newer ones with no luck.
              • Steven B.
                • April 11, 2012
                • 233
                Re: Scan Tool
                I purchased an Innova in 2009 through Amazon but put it on the shelf after I purchased a newer model that will pull codes for ABS. They still show this model as available. There is another that they say is OBD1 and OBD2 compliant and will also look at ABS. Go to Amazon and paste this into the search window. I never used the 3140 on an OBD1 vehicle so I can't say for sure whether it is in fact compliant.
                INNOVA 3140 OBD2/OBD1 Scan Tool with OBD2 Live Data
                Steve
                  • 43236
                  Re: Scan Tool
                  Steve
                  Steve------
                  I have and use an Innova 3140. It does work for both OBD I & II but not ABS. I've used it for both OBD I & II and it works fine. At the time I bought it, to get ABS functionality you could only also get OBD II. Having OBD I and OBD II was more important to me than having only OBD II and ABS.
                  The Innova 3140 works fine on my 1992 Corvette, so I'm sure it will work as well for a 1993, the subject of the OP's inquiry.
                  • David K.
                    • September 30, 1979
                    • 241
                    Re: Scan Tool
                    Check on eBay for a Tech 1, it will do abs, low tire sensors, active handling.
                    • Douglas L.
                      • May 8, 2015
                      • 181
                      Re: Scan Tool
                      Its been awhile, but as remember, aside from the Tech1 the snap-on MT2500 was about the best thing out there for the OBD-1 GMs. They pop up on Ebay pretty often, just make sure you're getting the correct cable and personality key for your application.
                      • Keith B.
                        • 1584
                        Re: Scan Tool
                        the key is K-9
