1967 shock recommendations - NCRS Discussion Boards
  • John P.
    • September 30, 2004
    • 22
    My L79 needs new shocks. The car is a recent TF car and my question is should I buy dated NCRS correct shocks or other better performing shocks. If I do go with dated correct shocks where is the best source? If i go with something better performing what is the recommendation? Thanks in advance for your input.
    John
  • Gary J.
    • April 1, 1980
    • 1244
    Re: 1967 shock recommendations
    I don't know about the performance of the dated shock, but be prepare to pay about a $1000.00 for them.
    • Joe R.
      • July 31, 1976
      • 4551
      John,
      Buying new Delco shocks would be wise and save a lot of money. Paint them the correct color and add the stickers. You wont loose many points and since you are already top flight you can stand a few deducts.
      JR
        • 43247
        John
        John-------
        Overall, your best bet are the current GM/Delco shocks.
        front------GM #88947653, aka Delco 530-315
        rear-------GM #88945172, aka Delco 530-4
        As JR says, remove the labels, paint them with the Quanta shock gray, and add the broadcast code labels.
        • John P.
          • 22
          Joe and Joe,
          Thank you for the recommendation. Where can you get the Quanta shock gray?
          • Joe R.
            • July 31, 1976
            • 4551
            John,
            LI 45-04 $10.00 plus shipping. 1 800 466-6367
            JR
            • Daniel S.
              • January 14, 2011
              • 309
              If you really want the best shock for the $ which will provide a better driving experience, get a set of KYB Gas Shocks. I have a set on my 70 LT1 Convert and 69 Z28. Great product if you drive your cars. If you want the assembly line correct option, call Dan Patch and get a set of his restoration shocks. Amazing craftsmanship. I spoke to him last week about a set and he's back logged 16 weeks at that point. Cost is as mentioned above - $1000/set. Good luck!
              http://www.jegs.com/i/KYB/575/KG4550/10002/-1
              http://www.jegs.com/i/KYB/575/KG5501/10002/-1
              • Edmund C.
                • April 14, 2015
                • 232
                John: I bought the Delco Shocks ($140.00) from Corvette Central and painted them with the recommended Quanta paint ($14.00) and added the appropriate decals from Paragon ($3.75). They look good on the vehicle. I looked into buying the above-referenced $1,000.00 shocks, yet, thought the latter route was more prudent. Good luck. Best, Ned
                • Dan P.
                  • December 1, 1990
                  • 683
                  I can do your shocks that will pas judging Dan 9one3 5one5 372one
                  • Joe R.
                    • July 31, 1976
                    • 4551
                    Are you performing this service for NCRS members free or do you charge? It is customary to pay for advertising in "The Restorer" and use this forum for technical advise.
                    HINT HINT!
                    JR
