I am replacing the dry-rot weather stripping on the front splash shields of my '64 convert. I removed the right side shield but it did not have a weather strip - nor does it have any staple holes from previously existing weather strip. I suspect a PO replaced the original or missing right side shield with a new after market unit but did not bother to install a new weather strip on this side.
Would appreciate advice from any '64 owners re the positioning of the staples on the right side. The left side shield had four stables were pretty much evenly spaced. If I spaced them the same way on the right side one or more staples would be in the bend area that fits around the battery support bracket. So, my question is, where do stales go, just along the two straight edges on either side of the bend or does one or more go in the bend area? For what it is worth neither the AIM or JG specify how many or where the staples should be positioned.
Pic of right side splash shield is attached as a reference.
That's life. Guess I will take the points for non original parts vs, missing and useless.
