need a trained eye - 64 wheel ID - NCRS Discussion Boards
  • Greg H.
    • June 2, 2008
    • 254
    Can anyone tell from these pics if this is a 64 steel wheel?
    • 6942
    Re: need a trained eye - 64 wheel ID
    Greg, that does not look like the 63/64 wheel the rear side should be tapered, they appear to flat. If you need a pic send me a pm with your email.
    • John D.
      • December 1, 1979
      • 5507
      Greg, Definitely not a 63-64 wheel. Many posts on this subject and pics. Maybe someone will pull one up for you. John
      • Brad V.
        • May 2, 2015
        • 30
        From my understanding from these forums (related pics from these forums).
        - 63-E64 look similar
        - L64 has hole in raised face
        - Should have [GM] stamp on ext face, no other markings
        - Small valve hole
        - Two raised nubs by valve hole
        - Tapered interior
        - Welded
        - Stamp not visible without removing tire [15 x 5 1/2 K] [YY M]
        Starting w/ 65 notched to make room for disk brakes
        63-66 Service replacements (3838080) have another slight notch and ext markings
        Pic Rim = Photo Comparison of 63-64 vs 65-66
        Pic Rim_2 = Spec Comparison of 63-64 vs 65-66
        Pic Rim2.1 = Spec Service replacement (3838080)
        • Chuck G.
          • May 31, 1982
          • 2034
          Here are some pics of 63 wheels. Note the rear taper. 64's look the same except for a 'drain hole" drilled in the spider, IIRC
          • Greg H.
            • June 2, 2008
            • 254
            Thanks, everyone. I was able to see many posts on the subject but when it came to seeing a picture I was unsure. Had I seen the wheels in person I think I would have gotten by. The pics helped very much!
            • David L.
              • July 31, 1980
              • 3310
              - Small valve hole
              - Tapered interior
              - Welded
              Brad,
              Those look like my drawings from the 1990's.
              Enclosed are tracings of the stampings on a Jan. 1963 Corvette wheel and a Jan. 1964 Corvette wheel.
              Dave
              • Brad V.
                • May 2, 2015
                • 30
                Thanks Dave, more great pics to add to my local archive. I knew I found those pic here somewhere but unsure who to provide credit. I tend to save off the pictures for easier access later (vs combing through years of message posts).
                I really wish we (NCRS) had an online picture archive sorted by year and judging section for reference (in color ). I know this is not a new topic but it would be nice. As a new member I've learned so much from the knowledge of this forum, but a picture is worth a 1000 words.
                • Alan D.
                  • January 1, 2005
                  • 2038
                  Brad,
                  Agree with you on pictures however that's a lot of WORK for somebody. Hope NCRS is saving all these pictures for some future time.
                  Here is my 64 wheel, from a March car, original spare.
