Radiator overflow tank - NCRS Discussion Boards
  • William T.
    Infrequent User
    • April 1, 1999
    • 1
    Were 1968 Corvettes equipped with the aluminum radiator overflow tanks, mounted inside engine compartment on passenger's side wheel well? Thank you for ant responses.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Radiator overflow tank
    The one word answer to your question is yes. Not all '68 Corvette had aluminum radiators or expansion/surge/overflow tanks though. It all depends on the engine option.
      • 43271
      William------
      Small blocks with manual transmission used aluminum supply tanks. Small blocks with Turbo-Hydramatic transmission and all big blocks except L-88 did not use external supply tanks. L-88 did use an external supply tank.
