Metal Platers in or around Texas - NCRS Discussion Boards
  • Joseph S.
    • October 27, 2014
    • 188
    Looking for some suggestions on good quality Zinc, Cad, Zinc Phosphate, and / or black oxide platers in or around the Texas.
  • Michael F.
    • 745
    Re: Metal Platers in or around Texas
    A1 I think it is called in fort worth off I35 south
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
    • Ken R.
      • August 31, 1980
      • 308
      Would this be it? Al's
      http://www.manta.com/c/mm7np1q/al-s-plating-co
      It is south of downtown and west of I-35.
      • Michael F.
        • 745
        yes I believe that is it.
        Michael
        • D S.
          • March 1, 2005
          • 1551
          Many friends and I have used Al's for years. They also know flash chroming. Thumbs up.
          Scott Sims
          Texas Chapter
          • Gary C.
            Administrator
            • October 1, 1982
            • 17773
            Joe,
            Might check with Dan Martin who lives close to you in New Braunfels for platers.
            Dan's contact information is in the Community menu Members List pull down.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Phil D.
              • January 17, 2008
              • 206
              Have used Als for chrome and tin. Zinc, yellow chromate, zinc phosphate, magnesium phosphate and black oxide I do myself partly because I sort of enjoy it but mostly because I can keep my nuts and bolts separated, bagged and tagged rather than batch plating at a shop and then trying to sort it all out. Zinc and phosphates are quite a bit of investment in equipment and time of course. However, for black oxide, its so incredibly fast, easy and cheap to DIY that you might want to give it a try yourself. http://www.caswellplating.com/black-...te-1-pint.html You literally dip bare bolts in room temperature solution for like 30 seconds, rinse and then treat with whatever rust preventative you prefer such as Gibbs brand penetrating oil. And a little bit of solution goes a long way and seems to last for years.
