Burned Coil Lead Wire - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    Hello everyone,
    My coil lead wire broke when I removed it. It appears to be due to an overheat condition as it is burnt and sooty looking (see picture). It's a L68 with TI. Any ideas on what would cause this?
    Jack
    Jack Ottofaro
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Burned Coil Lead Wire
    Jack,
    The wire must have ground out against the ignition shield at some point.
    • Scott S.
      • March 1, 1979
      • 747
      Jack, I melted one on our 1967. The terminals on the coil should be across the car not front and back. This will prevent the ignition shielding from contacting the terminals. I is hard to find pink wire, I used white colored with nail polish.
      Scott
      • Jack O.
        • July 31, 1996
        • 527
        Thanks Gene and Scott. I just purchased the car so something like that probably happened.
        Jack Ottofaro
