Re: 63 327/300 Overheating
Joe is right, as usual, and you also have an FI type radiator core support with the big hole to left of radiator for FI air cleaner air intake.
Much air that should pass through your radiator is going through that hole instead. You should make up a cover to block that hole.
Do that, replace your radiator with aluminum and replace your fan clutch and you should be running cool as a cucumber.
