C2 1966 Engine Pad Help - NCRS Discussion Boards
  • Frank C.
    • August 31, 2003
    • 171
    Need help with this pad. I am looking at this car, 1966 Convertible L72. Owner claims original engine. Before I spend additional time, and ask owner to clean the pad, is the stamping typical of production?
    Thanks Frank
  • Joe R.
    • July 31, 1976
    • 4552
    Re: C2 1966 Engine Pad Help
    Yes, have him clean with mineral spirits and post again.
    JR
    • Larry M.
      • January 1, 1992
      • 2701
      JR
      Mineral spirits won't get it done.............but lacquer thinner will. Also paint remover.
      Use NO ABRASIVES.
      Larry
      • Frank C.
        • August 31, 2003
        • 171
        Hello again. I am attaching a picture of this pad without paint. Need some help. Does this stamp and pad look original?
        Thanks Frank
        • Mark H.
          • October 28, 2014
          • 3
          That P is very suspect and I am no expert.
          • Mark D.
            1984-96 Team Leader
            • June 30, 1988
            • 2167
            What should it look like?
            Kramden
            • John G.
              • January 1, 2006
              • 85
              According to the lime book; IP= 1966 427/425 4bbl mt corvette.
              John G
              • Joe R.
                • July 31, 1976
                • 4552
                Frank,
                Nothing wrong with what I see. Broach marks intact and characters look good.
                Wait for the expert. He will chime in!
                JR
                • Tom D.
                  • September 30, 1981
                  • 2143
                  The "P" only looks light compared with the front end, the other end, of the ASM number. Looks like that string of numbers gets less deep as you read from left to right. This probably happened on half the stamps in 1966. I would not be worried.
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                  • Patrick B.
                    • August 31, 1985
                    • 2009
                    The fonts look good and the grain looks good. It is just struck heavy on the T side which makes it light on the P side.
                    • Patrick T.
                      • September 30, 1999
                      • 1286
                      Here is my '67 pad, same way.
