Oil Canister Spring ('63 to '67) - NCRS Discussion Boards
  • Rob A.
    • February 8, 2011
    • 135
    Did all C2 oil canisters have a spring at the bottom of the oil canister? (the spring is at the inside bottom of the canister and is placed over the center bolt) My '63 coupe has one but my '67 435hp does not. It appears that it should have the spring to press the filter tight to the block.
    Thanks for your input and advice.
  • Larry M.
    • January 1, 1992
    • 2701
    Re: Oil Canister Spring ('63 to '67)
    Yes.........they all had springs in the can when first installed on the engine.
    You can buy a rebuild kit from LICS and do it yourself, or send out for a restoration.
    Larry
    • Leif A.
      • August 31, 1997
      • 3646
      Larry
      Larry,
      The problem with their kit is that it does NOT include the cup and spring.
      Leif
      • Rob A.
        • February 8, 2011
        • 135
        Does anyone sell the cup and spring? Or do you need to buy either a reproduction canister or complete used one?
        • Larry M.
          • January 1, 1992
          • 2701
          Originally posted by Leif Anderson (29632)
          Larry,
          http://www.parts123.com/parts123/yb....Z5Z5Z50000370a
          Good point. Thanks for keeping me honest. I guess that leaves either a "restoration", or buying a good used can on Ebay...............and then either using that can or salvaging the parts to rebuild the one you have.
          I bought the reproduction can from Paragon many years ago, but eventually got my original restored by Ken Hansen. The wall thickness of the reproduction can was thinner with less gasket sealing surface. I felt the HD original was much better. My restored can from Ken was simply "outstanding". He may still do this work.
          Larry
          • Frank D.
            • December 27, 2007
            • 2703
            I couldn't find anybody that sells the cup and spring when I was looking....somebody had used some Bubba spring in mine and the cup was an old freeze plug somebody had drilled a hole in for the bolt. Apparently - this had worked for many, many oil filter changes...
