1970 350/350 Hard Start - NCRS Discussion Boards
    • 15706
    Re: 1970 350/350 Hard Start
    Originally posted by Duane Dunlap (50312)
    I plan to start with Leif's suggestion to accurately set the timing to factory specs.
    The initial timing spec is 8 BTC, and with no vacuum advance, that's total idle advance, and it's is the reason why the excessively hot exhaust manifolds are frying everything in the engine compartment.
    • Mike F.
      • April 25, 2011
      • 668
      I also have a 70 350/350, the timing, TCS, etc.. are all set-up factory correct and functioning. When I started having the same problem as you, it turned out to be the Restoration battery. Just not enough cold cranking amps. A generic battery from the local auto parts shop fixed the problem. I use the restoration battery for judging events.
      • Duane D.
        • April 15, 2009
        • 67
        #18
        Mike,
        Thanks for your response. After reading some of the Restoration battery stories, the battery was the prime suspect. I do disconnect the battery after use and it appears to be working ok. I am very careful to make sure the battery is fully charged before use. However, I do plan to replace the battery with a more powerful battery for normal use. I have tried more potent batteries over the last 50 years without success. The battery contributes to the problem, but I don't think it is the root cause. Again, thanks for your comments.
